Setup Floating License Environment 2005-11-28
With a floating license, a number of client machines can work with Visual Paradigm’s product concurrently based on limit on the concurrent access specified on the floating license.
Setting up Floating License Server with no ui 2005-11-28
There may have several reasons that cause floating license server unable to function. Points below are typical causes of not able to start application with floating license server. If you have received the message “Your License Key(s) are invalid, the application will exit!”, most likely at least of one of the problem below has occured.
Problem on Starting Application with Floating License 2005-11-28
