Tips and Tricks
O/R Mapping
Mac OS X
Tips & Tricks - License Key Topics
Recent Articles
Upgrading Your Tool with the Upgrade Key Upgrading Your Tool with the Upgrade Key
2005-11-28
As Visual Paradigm aims at providing quality products to our users, the usability of the CASE tools are improved from time-to-time. For each version upgrade, Visual Paradigm will send you an upgrade key to upgrade the software if it is under maintenance. Here is an example showing you how to upgrade the license key of Visual Paradigm for UML (VP-UML) from version 5.0 to 5.1.
Changing License Key from Evaluation Key to Purchased Key Changing License Key from Evaluation Key to Purchased Key
2005-11-28
You may have an interest in Visual Paradigm’s product(s) after evaluation and purchase our product(s). Once you have submitted your purchase order, we will send you a temporary purchased license key which lasts for 15 days. After the payment approved, a permanent purchased license key will send to you accordingly.
Removing License Key Repository Removing License Key Repository
2005-11-28
Importing license key inappropriately can cause you to corrupt the license key repository. The only solution possible at that point would be removing all the existing keys and then re-importing them again.
Invalid License Key Incorrect Edition
2005-11-28
This problem is usually caused by a mismatch between the acquired key and the installed product. To solve this problem, please justify the product edition to make the key functionable for the installed product. Product edition can be changed with Product Edition Manager. Here is a demonstration of the solution.
Last modified: 2005/11/29 02:15
Home | Recent Topics | Highlights | UML Diagrams | Tips and Tricks | Object-Relational Mapping
visual-paradigm.com Home | Training Center | UML Center | VP Gallery | Discussion Forum | UML Open Directory
